https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Idle pattern of sigma-delta A/D converters https://designers-guide.org/forum/YaBB.pl?num=1173007495 Message started by ywguo on Mar 4th, 2007, 3:24am |
Title: Idle pattern of sigma-delta A/D converters Post by ywguo on Mar 4th, 2007, 3:24am Hi, Guys, What is idle pattern? Is it always at half the sampling frequency for one-bit sigma-delta A/D or multi-bit sigma-delta A/D? Thanks Yawei |
Title: Re: Idle pattern of sigma-delta A/D converters Post by vivkr on Mar 5th, 2007, 2:53am Dear Yawei, The idle pattern is the response of a modulator to a DC excitation. On average, it should be at Fs/2 for a modulator with 1-bit quantizer, and also for a multibit one if I understand correctly because only 2 of the multibit levels are likely to be used (closest to the midlevel) unless you add randomizing dither to break the tones, which for a multibit delta-sigma is the standard way to remove idle patterns, and which does not work well for 1-bit quantizers. However, the topic is relatively complex. I would recommend that you look at a book on introductory nonlinear systems. A good visualization is also offered in the book "Understanding delta sigma converters" by Schreier and Temes in Chapter 2 (See Fig. 2.23). Regards Vivek |
Title: Re: Idle pattern of sigma-delta A/D converters Post by ywguo on Mar 7th, 2007, 6:26pm Dear Vivek, Thanks. Somebody recommended that book to me, too. I will try to get that book and read it. Yawei |
