https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Help for unit element in ladder DAC.. https://designers-guide.org/forum/YaBB.pl?num=1173336440 Message started by Marko on Mar 7th, 2007, 10:47pm |
Title: Help for unit element in ladder DAC.. Post by Marko on Mar 7th, 2007, 10:47pm Hello all, I am designing a 10 bit resistive ladder DAC with 2 resistive strings(LSB and MSB). To have a good matching between the two ladders I have the lsb resistor as unit element and constructed msb ladder in terms of unit lsb i.e 1 lsb resistor = 234Ω, 1 msb =32x234 = 7.5KΩ.My question is: 1. How to want to find a relation so that σR/Runit < 0.1Runit 2. Any documents or online material for this type of random variable analysis.. Thanks //Marko |
