https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> designing 75 ohm preamplifer https://designers-guide.org/forum/YaBB.pl?num=1173525598 Message started by mhtplsh on Mar 10th, 2007, 3:19am |
Title: designing 75 ohm preamplifer Post by mhtplsh on Mar 10th, 2007, 3:19am All the s parameters r available in 50 ohms. The noise figure GO, rn is also available in 50 ohms. Now i want to design 75 ohm input output preamplifier. I wish to start design with the help of quicksmith. Should i input the 50 ohms s parameters & just change chart parameter to 75 ohms or any other method? what to do with noise parameters of 50 ohms? Suggest how should i start for designing for 75 ohm input output? |
Title: Re: designing 75 ohm preamplifer Post by didac on Mar 12th, 2007, 12:33am I think that in quiksmith there's an option to change the characteristic Impedande(Zo) to any value that you need, so I think that you can design without any problem. |
