https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Load and save command in spectre? https://designers-guide.org/forum/YaBB.pl?num=1173613188 Message started by Amit Singh on Mar 11th, 2007, 4:39am |
Title: Load and save command in spectre? Post by Amit Singh on Mar 11th, 2007, 4:39am Hi, I am facing problem ragarding the long simulation time of the closed loop of CDR. It takes several hours for one run of the closed loop to get stable i.e control voltage to stabilise. In some simulator there are load and save commands to save stable node voltages after some time and then they can be used in other simulations. I am not aware if this feature is available in spectre. If there is a way to do this please let me know the proceedure. Best Regards, |
Title: Re: Load and save command in spectre? Post by Andrew Beckett on Mar 15th, 2007, 6:48am From spectre -h tran: Code:
Regards, Andrew. |
