https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> biasing current https://designers-guide.org/forum/YaBB.pl?num=1173691456 Message started by aaron_do on Mar 12th, 2007, 2:24am |
Title: biasing current Post by aaron_do on Mar 12th, 2007, 2:24am Hi all, I've found that the resistor variation from the model to the fabricated one can be enormous. For a biasing circuit like a bandgap reference, resistors are quite necessary (although I've seen some resistorless designs). This causes the results to be very different from expected. What kind of techniques do people use to get around that? Also, what is a good CMOS bandgap for 1.8 V supply? thanks, Aaron |
Title: Re: biasing current Post by monte78 on Mar 12th, 2007, 2:35am The point is that you cannot obtain an accurate value of resistors, but you can obtain an accurate matching of resistors. Usually you design a bandgape reference where your voltage reference depends on the ratio of resistors and on base-emitter voltages. You can search here for some ideas: http://www.circuitsage.com/bandgap.html aaron_do wrote on Mar 12th, 2007, 2:24am:
Title: Re: biasing current Post by Venkateshr on Mar 12th, 2007, 5:47am For the Voltage BG ref the question is over matching of resistors and not individual resistor tolerance.but for Iref it is Vbg/R like ckt which depends on R inversely and in first order itself.Here we should see to the variations of resistor with process (also with temp but this can be compensated) :'( |
Title: Re: biasing current Post by aaron_do on Mar 12th, 2007, 8:53am thanks for the replies. As Venkateshr pointed out the current produced by the current mirrors in the BG circuit is sensitive to resistor variation. I did find a paper which seems to have a solution to this problem though... "A new low voltage precision CMOS current reference with no external components" it can be found from IEEE xplore cheers, Aaron |
