Design Languages >> Verilog-AMS >> Printing Instance name in Ultrasim
https://designers-guide.org/forum/YaBB.pl?num=1173704006
Message started by Venkateshr on Mar 12th, 2007, 4:53am
Title: Printing Instance name in Ultrasim
Post by Venkateshr on Mar 12th, 2007, 4:53am
Hello Guys ,
                  I need to print the instance name from a Verilog-a block in ultrasim.Previously I did in spectre using "write("%m")" construct but in ultrasim it is not printing properly(it is printing as  "instance_<module name>_<number>"   .I think ultrasim is a fast spice simulator which is very much compatible with spectre but I am very very new to usim.Can you help me ASAP?Very urgent....
Thanks
Venkatesh R
Title: Re: Printing Instance name in Ultrasim
Post by Geoffrey_Coram on Mar 13th, 2007, 6:25am
%m is the correct code, per the Verilog-AMS LRM, so if your simulator is not printing what you want, you have to contact the vendor and file a bug report.
Since the "fast spice" simulators have some sort of hierarchical representation of the circuit, it may not be possible to print exactly what you want without compromising performance ...
