https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Spectre simulator speed impact with inline subckt? https://designers-guide.org/forum/YaBB.pl?num=1173811179 Message started by bernd on Mar 13th, 2007, 11:39am |
Title: Spectre simulator speed impact with inline subckt? Post by bernd on Mar 13th, 2007, 11:39am Hi, I'm planing to reorganize our model file structure, with the target that every mos transistor device should call an inline subckt. This makes it easier to deal with different requirements like monte carlo analysis or gate leakage simulation, you can use the same model name and just change the model file section regarding simulation purpose. The question now is how does this method affect the speed of the simulator 'Spetre'? Did someone had experience with this? Using inline subckt nch ( d g s b ) parameters ... n12 ( d g s b ) nch_core ... model nch_core bsim3v3 { ... } Rather than just model nch bsim3v3 { ... } Any thoughts? Bernd |
