https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Lag-Lead Filter Design https://designers-guide.org/forum/YaBB.pl?num=1174053552 Message started by elec_eng on Mar 16th, 2007, 6:59am |
Title: Lag-Lead Filter Design Post by elec_eng on Mar 16th, 2007, 6:59am Hi. I need to use a lag-lead filter. The configuration of this filter can be seen on the attachment. It will be used on a PLL cirucit with chip LM565. The data sheet can be found at: http://www.national.com/ds/LM/LM565.pdf I need to work out the values for C1, C2 and R2 if the cut off frequency is 1kHz. What equations can i use? OR What would the values for C1, C2 and R2 need to be? Please help. Thanks. |
