https://designers-guide.org/forum/YaBB.pl Design >> High-Speed I/O Design >> CDR Clock https://designers-guide.org/forum/YaBB.pl?num=1174287928 Message started by Amit Singh on Mar 19th, 2007, 12:05am |
Title: CDR Clock Post by Amit Singh on Mar 19th, 2007, 12:05am Hi, I am working a Clock data recovery circuit at 6.5G in 0.18um tech. Do i need to saturate the clock after the VCO, or is it ok to feed the sine clock to the phase detector. Thanks for the help, |
Title: Re: CDR Clock Post by SATurn on Mar 21st, 2007, 10:28am Hello, It depends on your PD topology. If it is based on SCL (source-coupled logic) topology, then it should be fine. Else, you are using CMOS gates in your PD, you should convert the levels to CMOS level. SATurn |
