https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> What is off-axis drain-source implantation? https://designers-guide.org/forum/YaBB.pl?num=1174445614 Message started by ywguo on Mar 20th, 2007, 7:53pm |
Title: What is off-axis drain-source implantation? Post by ywguo on Mar 20th, 2007, 7:53pm Hi, Guys, I am studying Yasuyuki Nakamura's "A 10-b 70-MS/s CMOS D/A Converter" in JSSC, April, 1991. It claims that A differential linearity error caused by an off-axis drain-source implantation is reduced by the layout technique of current sources. Any explanation of the off-axis drain-source implantation is welcome. Thanks Yawei |
Title: Re: What is off-axis drain-source implantation? Post by Croaker on Mar 21st, 2007, 7:06am I think it means the implanting of the S/D is happening at an angle. |
Title: Re: What is off-axis drain-source implantation? Post by ywguo on Mar 21st, 2007, 6:33pm Thanks. Does it mean the implantation is not orthogonal to the wafer? One more question, is that technique applied in DSM CMOS technology like 0.18um and nano technology like 90nm and 65nm? Thanks Yawei |
Title: Re: What is off-axis drain-source implantation? Post by sheldon on Mar 21st, 2007, 6:47pm Yawei, First, implantation is used to precisely control the doping of Silicon. The knobs for controlling implanation are dose, concentration, and the energy, depth. The challenge is that Silicon is a crystal and the implanted dopant tends to find the lattice and travel much father than intended. The dopant stops when it "hits" something. To prevent this phenomena, process engineers use several approaches, including off-axis implantation. By implanting "across" the lattice, the likelyhood of hitting the lattice increases and the depth of the implant can be more precisely controlled. To be honest, I have never heard of anybody actually intentionally implanting on-axis. BTW, other mtehods include scattering oxide and amorphization. Scattering oxides are usually thin oxide layers that tend to randomly scatter the dopant. Amorphization, sorry the spelling may be incorrect, is done by hurling something big and neutral, usually Aragon, at the Silicon prior to the implant. The Aragon, turns the Silicon matrix into amorphous mush so Silicon scatters the dopant. Best Regards, Sheldon |
Title: Re: What is off-axis drain-source implantation? Post by ywguo on Mar 21st, 2007, 6:59pm Hi, Sheldon, So clear. Thanks. |
