https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Threshold Voltage https://designers-guide.org/forum/YaBB.pl?num=1174465765 Message started by avlsi on Mar 21st, 2007, 1:29am |
Title: Threshold Voltage Post by avlsi on Mar 21st, 2007, 1:29am Hi all, As we increase the channel length, why is that the threshold voltage decreases? What is the reason behind this? Thanks in advance. |
Title: Re: Threshold Voltage Post by Michiel on Mar 22nd, 2007, 4:25pm avlsi wrote on Mar 21st, 2007, 1:29am:
There are many factors that influence the threshold voltage. Some basic ones are described in books like "Design of Analog CMOS Integrated Circuits". http://www.designers-guide.org/Books/ Personally I don't even want to know all the physics behind it. There is only one reliable way to make sure that two transistors have about the same (nominal) threshold voltage. Use identical parameters and layout. |
Title: Re: Threshold Voltage Post by krishnap on Mar 23rd, 2007, 3:02am Because of short channel effects VT decreases as channel length decreases. Exception to this is Reverse short channel effect, where VT increases as channel length reduces. Best regards, Krishna |
Title: Re: Threshold Voltage Post by mg777 on Mar 23rd, 2007, 8:09am As L decreases the drain and source depletion regions steal more of the gate's field lines, so the VTH actually decreases while the subthreshold conduction increases. OTOH if tox decreases faster than L, then you put the gate back in control (Cox increases) leading to a better trade-off between VTH and subthreshold slope. M.G.Rajan www.eecalc.com |
Title: Re: Threshold Voltage Post by mc66 on Mar 29th, 2007, 7:11am there have roll off curve for vt eg: when L is between 0.13 ~ 0.4(just estimated, 130mn technology) , vt is decrease with L decrease (SCE effect) but when L is between 0.4um and above , vt is incresae with L decrease (RSCE effect , halo implant cause this) |
Title: Re: Threshold Voltage Post by SATurn on Mar 29th, 2007, 12:27pm By reducing the device length, the field created by drain (or source) can bend the fermi level inside the substrate and attract some minority carriers. There is a very good discussion on this issue in Taur's book. SATurn |
