https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> To Analyze electromigration https://designers-guide.org/forum/YaBB.pl?num=1174648367 Message started by krishnap on Mar 23rd, 2007, 4:12am |
Title: To Analyze electromigration Post by krishnap on Mar 23rd, 2007, 4:12am Which tool provides analysis of electromigration problems and IR drops, in the drawn layout Thanks and regards, Krishna |
Title: Re: To Analyze electromigration Post by Andrew Beckett on Apr 12th, 2007, 1:54am VAVO and VAEO (Virtuoso Analog VoltageStorm Option, and Virtuoso Analog ElectronStorm option). That's for custom layouts, and it works in conjunction with Assura RCX, and either spectre or Ultrasim. There's also VoltageStorm/ElectronStorm which work from DEF, and are for a digital place and route flow. Regards, Andrew. |
Title: Re: To Analyze electromigration Post by krishnap on Apr 12th, 2007, 4:40am Thanks Andrew .. It is useful info |
