https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> how about digital PLL? https://designers-guide.org/forum/YaBB.pl?num=1176161758 Message started by sapphire on Apr 9th, 2007, 4:35pm |
Title: how about digital PLL? Post by sapphire on Apr 9th, 2007, 4:35pm The said digital PLL consists of digital controlled oscillator, time to digital converter, and digital filter, and so on. TI proposed this concept in 2005. Is this a good topic for PHD thesis? What can be exployed then? Confused.... Thanks |
Title: Re: how about digital PLL? Post by adesign on Apr 9th, 2007, 8:40pm Jitter is the major issue with Digital PLL. You can research on "Controlling jitter in DPLL" |
Title: Re: how about digital PLL? Post by vivkr on Apr 10th, 2007, 2:39am sapphire wrote on Apr 9th, 2007, 4:35pm:
Hi sapphire, I am not sure if you are quite accurate with the dates and the inventors. I believe that the first ones to propose this were Motorala and they did this sometime in the early 90s or late 80s. I know this because I myself have used the concept and designed a digital PLL consisting of a digitally controlled oscillator and digital filters (no cap, charge-pump based filters) way back in 2000. And at that time, the Motorola paper was the reference. However, I don't remember exactly who wrote it. I will check and see if I can find it. As for PhD topic, that depends on what kind of improvements you propose to bring into the field. Regards Vivek |
Title: Re: how about digital PLL? Post by hyy95 on Apr 11th, 2007, 4:36pm DPLL is too easy to do, the algorithm in C can be done in less than 200 lines, and logic codes in verilog can be done in less than 2000 lines. I don't know why u want to do it as a PHD thesis since it's just a basic buiding block for a digital receiver. doing so is like designing a opamp as a PHD thesis. |
Title: Re: how about digital PLL? Post by fonseca.ha on Apr 12th, 2007, 11:34am hyy95 wrote on Apr 11th, 2007, 4:36pm:
I totally disagree that a Digital PLL is not a good topic for phD thesis. there are many things to be investigated. Sure you can make a Digital PLL with a few lines, like you can make an opamp with 7 transistors, but what frequency? what jitter? what bandwidth? can it compete with an analog PLL for performance? What about Digital PLLs for RF? Noadays, to my knowladge, for example the time to digital conversion in a DPLL has a resolution comparable to the performance of an analog PLL. can you investigate how to make it better? What about this, can you arrange a digital core that can make the BW of the transfer function from the Digital VCO to the output as high as possible while mantaining the BW of the transfer function from input to the output as low as possisble, sop that the DPLL can clean both its Digital VCO and its Input? Regards, H. |
Title: Re: how about digital PLL? Post by loose-electron on Apr 12th, 2007, 8:44pm Key thing of thesis research: It has to be new It has to go someplace never gone before It has to be something your thesis advisor and thesis committee are interested in and receptive to. Read the last requirement very very very carefully. academic survival 101: give them what they want to hear. :D :D :D :D :D :D :D :D :D :D |
Title: Re: how about digital PLL? Post by hyy95 on Apr 13th, 2007, 10:37pm maybe we are not talking about the same topic. I am not talking about DPLL used for analog or RF ckts, I am talking about the digital phase lock loop in a digital receiver. So there's no digital VCO for any analog/RF use. All the performance bottle neck comes from the ADC, after the ADC, everything is digital, running on a free-running clock. Digital phased lock loop is used to track carrier offset, there are lots of algorithms to improve the performance, but comparing to other part in the digital receiver, such as channel equalization, the DPLL is much easier. the idea of soft radio is move ADC up as high as possible, and after ADC, everything is done in the digital world. fonseca.ha wrote on Apr 12th, 2007, 11:34am:
Title: Re: how about digital PLL? Post by buckaroo on Apr 23rd, 2007, 10:02am hello i will work on DPLL, however, i know little about it at present, i want to be an expert on the project, haha:) i think DPLL has a bright torrow hyy95 wrote on Apr 13th, 2007, 10:37pm:
