https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> How to simulate reference spur of PLL ? https://designers-guide.org/forum/YaBB.pl?num=1176258356 Message started by ben-w on Apr 10th, 2007, 6:25pm |
Title: How to simulate reference spur of PLL ? Post by ben-w on Apr 10th, 2007, 6:25pm I wrote a PLL behavioral model using Verilog-a ,but at the output of VCO,i cann't see the reference spur. I use a nonideal CP model and �do fft in calculator to see the result.Can anyone tell me why?thanks a lot. |
Title: Re: How to simulate reference spur of PLL ? Post by sheldon on Apr 13th, 2007, 7:44pm Ben, There are several possibilities, 1) Is the VCO control voltage a nearly constant value without any noise or impulses? Probably a problem with the PFD, if the PFD is in its dead zone then there will be no reference spur. Basically, you will need to fix the PFD. 2) Does the VCO control voltage have noisy, ringing, jumps, etc.? The PLL may not be in lock yet. You should wait longer so that the PLL settles and achieves lock. 3) The VCO control line voltage is nearly constant, with impulses. The impulses should repeat at the reference frequency, this is the reference clock feeding through to the control line. In this case, if the fft does not show a reference spur, then the issue is probably in the calculation of the fft. The most likely problem is interpolation error, if you are using Spectre then you can: a) Use the zvcs, to re-sample the waveform and eliminate interpolation error. b) Use Ken Kundert's MATLAB function for calculating the phase noise, it should show the reference spur c) Use the four component to calculate the output frequency spectrum, note, you will probably need to create your own Verilog-A model to implement a window function. Good Luck! Best Regards, Sheldon |
