https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> how to simulate the pole zero https://designers-guide.org/forum/YaBB.pl?num=1176261309 Message started by stm2006 on Apr 10th, 2007, 8:15pm |
Title: how to simulate the pole zero Post by stm2006 on Apr 10th, 2007, 8:15pm I want to check the pole zero of opamp using pole zero analysis spectre simulator,there are a lot of pole zero summary in the simulation result. how to analysis the result?thanks. :o |
Title: Re: how to simulate the pole zero Post by chase.ng on Apr 10th, 2007, 8:43pm Hi, Most of the poles and zeros are at very high frequency, you will need to filter them out. There is option in the direct plot form. Regards, chase |
Title: Re: how to simulate the pole zero Post by stm2006 on Apr 11th, 2007, 6:33pm it is ture,there are manyparasitical poles in plot,but how can i get what i want. |
