https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> implement laplace_zp function from measurements https://designers-guide.org/forum/YaBB.pl?num=1176894359 Message started by Pavel on Apr 18th, 2007, 4:05am |
Title: implement laplace_zp function from measurements Post by Pavel on Apr 18th, 2007, 4:05am Hello, How to implement laplace_zp function from "pole-zero" analysis. The output from this analysis is done as table qfactor poles (Hz) 0.5 123.6 -0.5 4.5e+6 . . . . How to transform this data in paires (real, imaginary), required by laplace_zp function? Regards, Pavel. |
Title: Re: implement laplace_zp function from measurement Post by Saran on Apr 25th, 2007, 8:26am laplace_zp syntax is laplace_zp(input, {-z1,0,-z2,0}{-p1,0,-p2,0}) for a transfer function ((1+s/z1)(1+s/z2))/((1+s/p1)(1+s/p2)) where p1,p2,z1,z2 are real poles and zeros. You can get more information from LRM or a basic text book. However, if you are trying to implement a filter response based on poles and Q-factor values, then wouldn't it be easy to use laplace_nd on the transfer function? For instance, assume you have a biquad filter that is given by the TF w^2/(s^2+ s(w/Q)+w^2), w is the pole location(freq) and Q is the Q-factor. Use laplace_nd directly on this function. I guess what I am trying to say is, depends on what you want to do! Hope this helps. |
Title: Re: implement laplace_zp function from measurement Post by Pavel on Apr 26th, 2007, 3:15am What I want to do is create model in verilog-A of operational amplifier. I did zero-pole analysis of this OpAmp. The result of this anaysis is extracted poles and zeros in form of pairs (qfactor, pole) and conseuntly (qfactor, zero). How can I use these results to create OpAmp model in verilog-A. If you understand what I mean, could you, please, create lapalce function for following case: qfactor zeros (Hz) -0.5 1.81E+07 -0.5 1.84E+07 0.5 2.39E+07 -0.5 1.06E+08 qfactor poles (Hz) 0.5 5.727 0.5 1.24E+07 0.5 1.84E+07 0.5 2.38E+07 -0.5 3.57E+07 Regards, Pavel |
