https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Contour plots of Niose Figure https://designers-guide.org/forum/YaBB.pl?num=1177199217 Message started by SuperMentor on Apr 21st, 2007, 4:46pm |
Title: Contour plots of Niose Figure Post by SuperMentor on Apr 21st, 2007, 4:46pm Hi all, Can you tell me how I obtain the NF contour for LNA in the space of (Id and W) using the Cadence spectre as attached? Thank you |
Title: Re: Contour plots of Niose Figure Post by James Bond on Apr 22nd, 2007, 1:22am I have never tried this before, but I suggest you try using W as a variable and sweep it in a range ,and you will get different current. |
Title: Re: Contour plots of Niose Figure Post by ACWWong on Apr 26th, 2007, 2:57am sweeping for fixed NF doesn;t sound quick to do in spectre. It looks like the plot you have is generated from some equations and ploted in something like matlab/mathcad etc. anyway one (labourious) way to do it in cadence would be to sweep current for fixed W and tabluate NFmin (from an sp sim). Then step W and do it again. Then load the data into something like Excel or matlab to give the constant NF contours |
