https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> area of 12bit ADC https://designers-guide.org/forum/YaBB.pl?num=1177399672 Message started by hawaiime on Apr 24th, 2007, 12:27am |
Title: area of 12bit ADC Post by hawaiime on Apr 24th, 2007, 12:27am Does anyone know how big will be a 12bit ADC if using 0.35um process? |
Title: Re: area of 12bit ADC Post by ywguo on Apr 24th, 2007, 1:41am I guess it is 1 ~ 2 mm2 depending on the design. You'd better search the IEEE Explorer. :) Yawei |
Title: Re: area of 12bit ADC Post by Andrew Beckett on Apr 24th, 2007, 3:28am This is enormously dependent on the ADC architecture - whether is it flash, half-flash, sigma-delta, SAR, dual-ramp, etc, etc. Some of these can be pretty enormous, and some can be tiny. It depends... Andrew. |
Title: Re: area of 12bit ADC Post by hawaiime on Apr 24th, 2007, 8:43pm Thanks guys! |
