https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> current source convergence issues when open https://designers-guide.org/forum/YaBB.pl?num=1177987937 Message started by Croaker on Apr 30th, 2007, 7:52pm |
Title: current source convergence issues when open Post by Croaker on Apr 30th, 2007, 7:52pm Let's say I make a simple ideal current source, e.g. I( p, n ) <+ IDC. How do I make it such that there aren't convergence issues when it's open? You know, the voltage blows up if it's trying to make current flow into an open. |
Title: Re: current source convergence issues when open Post by Geoffrey_Coram on May 7th, 2007, 4:31am One way would be to put GMIN in your model: I( p, n ) <+ IDC + $simparam("gmin", 1e-12) * V(p,n); There isn't a GMIN in most simulator's ideal current sources, though. Why do you want one? |
Title: Re: current source convergence issues when open Post by Croaker on May 7th, 2007, 5:03am Thanks! I want one because I have a big circuit block and sometimes some of the pins won't be connected. |
