Design Languages >> Verilog-AMS >> How to make accumulator module use verilog-A?
https://designers-guide.org/forum/YaBB.pl?num=1178871526
Message started by icsoul on May 11th, 2007, 12:18am
Title: How to make accumulator module use verilog-A?
Post by icsoul on May 11th, 2007, 12:18am
Note: not verilog-AMS
Thanks for your help!!
Title: Re: How to make accumulator module use verilog-A?
Post by makelo on May 22nd, 2007, 1:23pm
You could build it up from the primitives given as examples in the modeling section. �There are plenty of VerilogA and, or, nands, and dff there. �This might be a good place to start.
Post by icsoul on May 25th, 2007, 1:38am
Than you for your advice!
