https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Spice thermistor... basically a volt var source.. https://designers-guide.org/forum/YaBB.pl?num=1180031139 Message started by groundhog on May 24th, 2007, 10:25am |
Title: Spice thermistor... basically a volt var source.. Post by groundhog on May 24th, 2007, 10:25am I have a simple BJT circuit in LTspice. I sweep it over temperature and the Ic changes. So, I want to insert a thermistor (temperature varying resistor) in the collector to counteract the variation in Ic. So, time to put in a model of a thermistor in for one of my collector resistors. But, the way to model a thermistor in Spice is to create a voltage controlled voltage source that creates a voltage that would be seen across the equivalent resistor that you are replacing. So if the 100 ohm resistor would have made a voltage drop of .1 volts, you just make it so that the voltage source drops .1 volt at the same current. The circuit doesn't know the diff. THE PROBLEM: |
Title: Re: Spice thermistor... basically a volt var sourc Post by groundhog on May 24th, 2007, 10:31am .... (sorry, I hit the wrong key and posted the above without finishing) THE PROBLEM: Is that in the descriptions I have seen in the thermistor model, you do a sweep of the control voltage and not temperature. So, if you want to see what the thermistor does over a range of say 0 to 50 degrees, you sweep the control voltage from 0 to 50 volts. You plot and just label the x axis as temperature rather than voltage. Well, with the BJT, you have to actually sweep real temperature. It's model has temperature varying elements in it. So I am left with sweeping two different things, temperature and control voltage in a nested sweep statement. I NEED A THERMISTOR MODEL WHERE YOU SWEEP TEMPERATURE NOT VOLTAGE TO MAKE IT CHANGE. does anyone know of one? |
Title: Re: Spice thermistor... basically a volt var sourc Post by Geoffrey_Coram on May 25th, 2007, 7:40am Why don't you use the TC1 parameter of the resistor to make it temperature dependent? |
Title: Re: Spice thermistor... basically a volt var source.. Post by Cryptonite on Mar 19th, 2009, 6:15am Hi, I know this is an old thread now but I had a similar need & found this board just this week while trying (and failing) to find a solution. I've now solved it myself & thought I'd share my solution which is to use an Arbitrary Behavioural Voltage Source combined with a 0V Voltage source as a current sensor like this: .subckt ntc 1 2 Params: * these provide sensible defaults + R0=10k, + Beta=7660, + Rpar=1T, + t0 = 25, + TK = 273.15 * Arbitrary Behavioural Voltage source is used to generate * Voltage equal to the NTC resistance @ global temp (in �C) * multiplied by the current passing through it BTherm 1 3 V = I(Vsense) * R0 * exp (Beta/(temp + TK) - Beta/(t0 + TK)) * Current sensor Vsense 3 2 0 Rparallel 1 2 R = Rpar .ends If you make this a library, you can then add commercially available Thermistors, e.g. * Vishay Surface Mount NTC0805E4 series 2k2 @ 25�C .subckt 2381_615_13222 1 2 x1 1 2 ntc Params: R0=2k2 Beta=3680 .ends and predefined linearised sensors such as *Oil Temperature Sensor .subckt OilTemp 1 2 x1 1 2 ntc Params: R0=50k Beta=1780 Rpar=18k .ends or you can just use the select "ntc" as SpiceModel and define the parameters as you need in the LTSpice Component Attribute Editor e.g. Value as "R0=15k" , Value2 as "Beta=4660", SpiceLine as "T0=0", SpiceLine2 as "Rpar=1k5" The model is obviously a simple one, with no account taken of frequency response, self-heating, etc. but it's much faster to run in LTSpice than the EPCOS ntc models available online. Hope this is useful to somebody! |
Title: Re: Spice thermistor... basically a volt var source.. Post by Frank Wiedmann on Mar 19th, 2009, 7:57am Are you aware of the LTspice users' group at http://tech.groups.yahoo.com/group/LTspice/ ? There you will find an answer to almost every LTspice-related question. |
Title: Re: Spice thermistor... basically a volt var source.. Post by Cryptonite on Mar 19th, 2009, 8:37am Yes, I am aware of the group's existence but I'm not a member. Unfortunately, because of the wide range of available, non-work related groups, Google Groups are generally frowned upon by our corporate network "guardians" (that's the polite word). Thanks for the suggestion, though! |
