https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> how miminum length should I used? https://designers-guide.org/forum/YaBB.pl?num=1180605786 Message started by Robert on May 31st, 2007, 3:03am |
Title: how miminum length should I used? Post by Robert on May 31st, 2007, 3:03am hi, all! i am designing a folded cascode OTA used in a LDO, to achive a acceptable offset caused by the transistor's mismatch, how miminum length of the input and load transistors should I used, my design is based on the Charter 0.35um CMOS process. please give me any suggestions from your tapeout experience, thanks a lot! best regards, Robert |
Title: Re: how miminum length should I used? Post by krishnap on May 31st, 2007, 3:44am Hi Robert, Usual practise is to keep minimum design length to be 2 to 3 times that of process node. In this case 2-3*0.35um Regards, Krishna |
Title: Re: how miminum length should I used? Post by Berti on Jun 4th, 2007, 12:20am Hello Robert, I think this depends on the offset you can tolerate. For applications where offset isn't the major concern, but speed is important I usually use minimum length transistors to take full advantage of the technology. If offset is important but speed moderate I agree with Krishna not to use minimum design length. Cheers, Thomas |
