https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> 2GHz single to differential buffer https://designers-guide.org/forum/YaBB.pl?num=1180770988 Message started by wave3x on Jun 2nd, 2007, 12:56am |
Title: 2GHz single to differential buffer Post by wave3x on Jun 2nd, 2007, 12:56am Dear guys, I want to design a high speed single to differential buffer, here my input is 2GHz rail-to-rail, and the convertor needs to be design for low noise application, harmonics of output differential signal does not care very much. any suggestion is welcome. |
Title: Re: 2GHz single to differential buffer Post by Faisal on Jun 14th, 2007, 1:53pm just curious whats the application ? |
Title: Re: 2GHz single to differential buffer Post by jeffyan on Jun 14th, 2007, 5:58pm wave3x wrote on Jun 2nd, 2007, 12:56am:
hi i think you can pass the signal to a inverter and a cmos pass-gate repectively, and reform the waves again by inverters. the other method is pass the original to a diff-amp with resistors load, and the other input is 1/2 vdd. hope this help. |
