https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Peak to average Power https://designers-guide.org/forum/YaBB.pl?num=1181139368 Message started by Nibblo on Jun 6th, 2007, 7:16am |
Title: Peak to average Power Post by Nibblo on Jun 6th, 2007, 7:16am I would like to know how the peak to average power is calculated using Cadence Spectre tools. This for a modulated signal measured at the output. I believe a simple measure of Vrms*Irms is not sufficient. This because the signal is a modulated signal. A few detailed steps using the cadence calculator would be appreciated. |
Title: Re: Peak to average Power Post by chase.ng on Jun 7th, 2007, 8:47pm Hi, Peak to average power is a ratio commonly known as PAPR, definately is not Vrms*Irms. If the load is constant, then Vrms^2/R will give the average power. To calculate the peak power, use Vpeak^2/(2*R). regards, chase |
Title: Re: Peak to average Power Post by Nibblo on Jun 8th, 2007, 3:32am The two equations you specify are the same mathematically :-) |
Title: Re: Peak to average Power Post by RFICDUDE on Jun 9th, 2007, 5:23am For a single sinusoid the two equations are the same. This is why a CW signal is said to have a PAPR = 1 or 0 dB. In general amplitude modulated signal have a PAPR > 0 dB, so you need to measure Vrms and Vpk as indicated in the expression (so long as you are measuring it across a load resistor R). |
Title: Re: Peak to average Power Post by chase.ng on Jun 12th, 2007, 10:17pm Hi RFICDUDE, Thanks for clarifying that, guess I didn't make it clear enough at the first place. :) Regards, chase |
