https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> simulation of switch capacitor circuit in Cadence https://designers-guide.org/forum/YaBB.pl?num=1181916921 Message started by tom55 on Jun 15th, 2007, 7:15am |
Title: simulation of switch capacitor circuit in Cadence Post by tom55 on Jun 15th, 2007, 7:15am Hi, I am designing a sc sigma delta modulator using the Cadence software. I am new to SC simulations and would like advice about which simulator should i use. Thanks in advance Ton |
Title: Re: simulation of switch capacitor circuit in Cade Post by sheldon on Jun 15th, 2007, 5:23pm Tom, The best place to start is http://www.designers-guide.org/Analysis/delta-sigma.pdf The issue is that while there many tools for simulating switched-capacitor circuits in SpectreRF, the overall simulation of the sigma-delta modulator is difficult. A Sigma-Delta modulator does not have a periodic steady-state so you will need to rely on transient analysis for verification. Best Regards, Sheldon |
