https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Generate Initial Guess for DC Solver Failed https://designers-guide.org/forum/YaBB.pl?num=1182214671 Message started by qiushidaren on Jun 18th, 2007, 5:57pm |
Title: Generate Initial Guess for DC Solver Failed Post by qiushidaren on Jun 18th, 2007, 5:57pm Hi all, When I do DC analysis using Analog Artist, I always meet such sentences like this: ********************* DC Analysis ‘dc0p’ ********************* Attempt to generate initial guess for DC solver failed. What is going on here, how can I solve this kind of problem, or it is not a problem or something? Rgds, Terry |
Title: Re: Generate Initial Guess for DC Solver Failed Post by Geoffrey_Coram on Jun 19th, 2007, 10:35am It's not a huge problem, as long as Spectre does eventually find a solution ... it might be taking longer than it should to find that solution. I think Spectre tries to make a "good" initial guess for DC Newton -- a "dumb" initial guess would be: all nodes are zero, except those that have voltage sources on them. One could attempt to improve upon this by using some heuristics to guess some other values: if you know the voltage on one side of a diode, then the voltage on the other side might be 0.6V higher. I think the message is saying that Spectre's heuristics are having trouble with your circuit topology or some of the device models. |
