https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> low voltage design technique https://designers-guide.org/forum/YaBB.pl?num=1182253025 Message started by jeremy_zhu on Jun 19th, 2007, 4:37am |
Title: low voltage design technique Post by jeremy_zhu on Jun 19th, 2007, 4:37am i'm trying to design a ultra-low voltage opa . the model i used to design it is a typical 0.5um CMOS model whose Vtn≈0.85(w/l 20/0.5) ,Vtp≈0.95(w/l 20/5.5), but my supply voltage is only sub-1v(0.9 or less). the opa must satisfy the specifications:>80dB 10~20Mhz GBW and constant gm with rail to rail ICMR. i want to know whether it can be realized for the model by some special technique :FG ,BULK-DRIVEN or some other ones. any special comments ,suggestions or useful references? |
Title: Re: low voltage design technique Post by carlgrace on Jun 27th, 2007, 5:30am Bulk driven will be very hard to meet specs. You will probably want to do a two stage op amp, with two input diff pairs, one is NMOS and one is PMOS. A very good book to get started is Laker and Sansen. You can also search for rail-to-rail input stages on Google. good luck, Carl |
Title: Re: low voltage design technique Post by vivkr on Jul 11th, 2007, 3:03am jeremy_zhu wrote on Jun 19th, 2007, 4:37am:
Hi Jeremy, While bulk-driven techniques may be not be optimal for your specs, you can certainly try to reduce the threshold voltages of your transistors by applying a small forward-bias to the bulk-source junction. Needless to say, this is fraught with peril in case you latchup. Regards Vivek |
Title: Re: low voltage design technique Post by JD on Aug 20th, 2007, 3:21pm No, it won't work unless you lower vtn and vtp. If your vdd < |vtn| + |vtp|, bulk driving maybe the only way to go. |
