https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Normalized phase noise the PLL https://designers-guide.org/forum/YaBB.pl?num=1183730071 Message started by dpienkow on Jul 6th, 2007, 6:54am |
Title: Normalized phase noise the PLL Post by dpienkow on Jul 6th, 2007, 6:54am Hello Experts, I am designing now the charge pump with phase detector for the PLL. At the moment I measure the phase noise at the output of the charge pump and observe the levels around -120 dBc @ 1kHz offset. Comparison frequency is 50 kHz. I do knot know, if it is good, very good or maybe poor result. Therefore, I would like to compare myself with state of the art circuit from National or Analog. They specify normalized phase noise for the PLL, which as far I understand should be the phase noise at the output of the charge pump. To compute total noise of the closed loop PLL, both companies give the equation PNtotal=PNpll+10*log(Fcomp)+20*log(N), where PNpll is what I am interested in. This formula suggest, that decreasing the comparison frequency in my simulations will decrease the phase noise. It is not the case in my simulation. Therefore I would like to ask you, how to compute (simulate) this normalized phase noise? Best Regards, Dariusz Pienkowski |
