Design >> RF Design >> region 0 in dc operation point
https://designers-guide.org/forum/YaBB.pl?num=1183733987
Message started by James Bond on Jul 6th, 2007, 6:59am
Title: region 0 in dc operation point
Post by James Bond on Jul 6th, 2007, 6:59am
Hi,
does anybody know 'region 0' in dc operation point mean triode region or cut off region ? I am simulatiing passive mixer, I found the four transistors are all working in the region 0 state, and I still get IF output.  But in my memory, region 0 represents cutoff state, and region 1 represents triode state, and one pair of switches of the mixer should work in the triode region, the other two should work in the cutoff state.
Best Regards
James
Title: Re: region 0 in dc operation point
Post by Ken Kundert on Jul 6th, 2007, 2:03pm
To find out, type "spectre -hs bsim3v3" and look for the description of the region parameter. It will give a list of regions. The first listed will be region 0, the second will be region 1, etc.
-Ken
Post by James Bond on Jul 6th, 2007, 2:19pm
Ken Kundert wrote on Jul 6th, 2007, 2:03pm:
To find out, type "spectre -hs bsim3v3" and look for the description of the region parameter. -Ken
Hi, Ken,
Thank you for the reply, could you kindly tell me where to input this command ?  I tried in CDS.log window, but it returns ''unbond variable -hs''
Post by boe on Jul 6th, 2007, 2:33pm
Command line (UNIX)
BOE
