https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Sampling capacitor size of ADC https://designers-guide.org/forum/YaBB.pl?num=1184078137 Message started by neoflash on Jul 10th, 2007, 7:35am |
Title: Sampling capacitor size of ADC Post by neoflash on Jul 10th, 2007, 7:35am In 2001, Abidi published a paper of "A 6-b 1.3-Gsample/s A/D Converter in 0.35-um CMOS". Only 6-bit resolution is required, however, Abidi and Michael Choi added 1pF as input sampling capacitor. The thermal noise due to KT/C is only about 2mV, which is much lower than LSB quantization noise. Why they put so much capacitance there and pay the cost for high power? thanks, Neo |
Title: Re: Sampling capacitor size of ADC Post by loose-electron on Jul 10th, 2007, 8:31am in all probablity the sizing can come from a bunch of different considerations and noise is the last one. charge injection of switches resistance of switches and sampling time period needed leakage rate of gates, hold time and droop characteristics plate dielectric leakage impedance that the hold capacitor sees smaller C is better for fast sampling times, but the nonideal nature of the switches makes for a need to store larger amounts of charge in order to get a stable voltage. |
Title: Re: Sampling capacitor size of ADC Post by vivkr on Jul 10th, 2007, 11:15pm Hi Neo, I think it is probably charge-injection and parasitic issues which are probably responsible in this case. If you look at Fig. 5 of this paper, you can see that the authors also use a dummy switch to prevent a jump in the common-mode level when going from track-to-hold phase. This switch is also useful in partially compensating for charge-injection. There are of course other ways of designing a sample-and-hold for less power consumption, but for this case (6-bit flash), it was probably the best way to do it this way. Be aware though that sometimes people may choose the cap size arbitrarily, and often the choice is 1 pF. Not in this case I think. However, I disagree with loose-electron when he says that noise is the last consideration for cap sizing. If you are making high-resolution circuits, it is often the first one, but for low-res, it may be the last. Regards Vivek |
Title: Re: Sampling capacitor size of ADC Post by neoflash on Jul 11th, 2007, 4:56am loose-electron wrote on Jul 10th, 2007, 8:31am:
I do not agree with your point. 1. "charge injection of switches" does decrease with bigger sampling capacitor. However, to maintain same bandwidth of T/H, more sampling capacitor will incur larger switch, which increase charge injection. In short, these two effects cancel each other. 2. gate leakage of capacitor also grows linearly with capacitor size. |
Title: Re: Sampling capacitor size of ADC Post by neoflash on Jul 11th, 2007, 4:58am vivkr wrote on Jul 10th, 2007, 11:15pm:
Thanks for your reply. However, i do not agree with charge injection part. Pls see my last reply. Thanks. Neo |
Title: Re: Sampling capacitor size of ADC Post by vivkr on Jul 11th, 2007, 6:08am neoflash wrote on Jul 11th, 2007, 4:58am:
Hi Neo, What you are basically saying is that the charge-injection vs.switch Ron factor is independent of cap size. In this you are correct. Perhaps it would be worthwhile asking the author himself. why he chose 1 pF. I can see no reason for the large size. Regards Vivek |
Title: Re: Sampling capacitor size of ADC Post by joeb on Jul 18th, 2007, 12:54am Hi Neo, I guess that in the proposed design they don't use dummy switches. They choose C=1pF in order to be sure that the charge injection has no effect. |
