https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> A question on the transient analysis of HSPICE https://designers-guide.org/forum/YaBB.pl?num=1184217808 Message started by dandelion on Jul 11th, 2007, 10:23pm |
Title: A question on the transient analysis of HSPICE Post by dandelion on Jul 11th, 2007, 10:23pm Hi, I have a question on the HSPICE tramsient analysis. My circyuit is a triangular wave gennerator. I found the waveform is good before 1ms. But when after the 1ms, the waveform becomes not so smooth. I checked the simulator and i found the time step becomes loose after 1ms. Key point here is the block is always in steady state from the begining. I tried the Smartspice, it is OK and no have this phenominon. Anyone pls. tell me why? Thank s a lot! |
Title: Re: A question on the transient analysis of HSPICE Post by ywguo on Jul 15th, 2007, 8:04pm Hi, What is the period of your triangular wave generator? What is the step size of your .tran command? Do you set .option method = gear instead of the default method=trag? What does the steady state mean? Yawei |
Title: Re: A question on the transient analysis of HSPICE Post by dandelion on Jul 15th, 2007, 11:45pm ywguo wrote on Jul 15th, 2007, 8:04pm:
Hi, The time point step size become loose after 1ms. The simulator use the default algorithm. The steady state mean the circuit have veru quick startup time because it is RC oscillator. The frequncy is about 350KHz. Pls. comment! Thanks |
Title: Re: A question on the transient analysis of HSPICE Post by ywguo on Jul 20th, 2007, 10:01am Hi, It is better to set the step size in .tran command less than one tenth of the triangular waveform generator. I guess that the step size is too large in your simulation. Best regards, Yawei |
