https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> question about vco loaded https://designers-guide.org/forum/YaBB.pl?num=1184240621 Message started by James Bond on Jul 12th, 2007, 4:43am |
Title: question about vco loaded Post by James Bond on Jul 12th, 2007, 4:43am Hi all, I am simulating the vco, polyphase and passive mixer together. I have an output amplitude 1.75Vpp from vco, after the polyphase filter, it becomes 800mVpp. But when I connect this output to mixer, it becomes 340mVpp which is not enough to drive mixer. It seems that a isolation amplifier would be useful placed between polyphase filter and mixer. But I am not sure how to build this kind of large input signal and high speed amplifier or I should use just a LC tank network to amplify the signal? Could you please give me some suggestions? Thank you vey much. |
Title: Re: question about vco loaded Post by mobil on Sep 20th, 2007, 10:32pm As u said, the buffer is needed between VCO and Mixer. And it's better to design VCO with buffer at the beginning |
