https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> Issues with Virtuoso AMS https://designers-guide.org/forum/YaBB.pl?num=1184442782 Message started by leena2k6 on Jul 14th, 2007, 12:53pm |
Title: Issues with Virtuoso AMS Post by leena2k6 on Jul 14th, 2007, 12:53pm Hi, I have recently started to develop AMS environment(Cadence Virtuoso AMS) at chip level. The testbench components are System Verilog and the design is mixed verilog + vhdl. While running verilog -irun ...command, i see some issues in ncelab. The error is something like - Hierarical component lookup failure testbench.top.......cfash0.ftop.IFLH FYI, the same pattern runs fine when run without ams options i.e without giving -propspath option in the verilog run command. Also the testbench is SV, top, cfash0 is verilog code, ftop is a vhdl code whereas IFLH is verilog. The cflash0, ftop, IFLH are all digital blocks. Any clues why do i see this issue? Thanks, Leena |
Title: Re: Issues with Virtuoso AMS Post by Daniel Liu on Aug 7th, 2007, 2:41pm Hi Leena, My name is Daniel Liu, AMS PE from Cadence. I got forward for your issues. I have good news for you. Ramkumar has been working with us and we are sending his an ER with this fix. Please check with him a little bit latter. Thanks, Daniel |
