https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Help needed about Matlab's windowed fft precision! https://designers-guide.org/forum/YaBB.pl?num=1184491436 Message started by greatqs on Jul 15th, 2007, 2:23am |
Title: Help needed about Matlab's windowed fft precision! Post by greatqs on Jul 15th, 2007, 2:23am Hi everybody, I've met a weird problem really makes me desperate. The problem is as below, As we know, hann window's spectrum is defined as[1]: W(phi)=0.5*D(phi)+0.25(D(phi-2*pi/N)+D(phi+2*pi/N)) where, D(phi)=exp(j*phi)*sin(N/2*phi)/sin(1/2*phi) is the Dirichlet kernel, and N is number of DFT points the amplitude of spectrum at the first fft bin (phi=0) should be N/2 the amplitude of spectrum at the second and last fft bin (phi=1*2pi/N and phi=(N-1)/N*2pi) should be N/4 the amplitude of spectrum at the rest of fft bins should be 0 hence, in theory, there should be 3 non-zero bins on the spectrum of hann window. But when I do this in Matlab, I found that the rest of fft bins' amplitude is not so small that it cannot be simply neglected. As can be seen from the picture in the attachment for N=1024, the first and second bin's amplitude is 0dB and -6dB as expected, but the rest bins' amplitude are not zero as theory says (they are around -70dB~-80dB). The consequence of this problem is that when I do fft with any sine wave plus noise of which the noise floor is below these non-signal bins' amplitude (for example the noise floor is around -100dB), Matlab simply gives me the wrong SNR!! I can not find any answers or related information from any textbook. I guess it is caused by Matlab fft's internal precision. Anyone has idea about this? Thanks a lot! [1] "On the use of windows for harmonic analysis with the discrete fourier transform", F. J. Harris, Proceedings of the IEEE VOL.66 NO.1, Jan. 1978 the matlab script I used (I'm using Matlab R2006b): close all; nbpts=1024; w=hann(nbpts); % generates hanning window vectors W=fft(w)/sum(w); % generates normalized fft spectrum WM=abs(W); % gets amplitude spectrum figure(1); plot([1:nbpts],20*log10(WM),'bo-'); xlabel('fft bin'); ylabel('dB'); title('Hann window DFT with N=1024 normalized spectrum'); grid on; |
Title: Re: Help needed about Matlab's windowed fft precis Post by vivkr on Jul 16th, 2007, 2:57am Hi, The internal precision of MATLAB is quite high. I think you have misinterpreted the properties of the window you are using, and mistaking the "main lobe width" for the number of nonzero bins. I don't think there is any window which would have the excellent properties you seek. Nevertheless, depending on the input signal which is operated on by the window, you may end up with just a finite number of nonzero bins. Regards Vivek |
