https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> "phase.vams", what is it? https://designers-guide.org/forum/YaBB.pl?num=1184747698 Message started by feihudui on Jul 18th, 2007, 1:34am |
Title: "phase.vams", what is it? Post by feihudui on Jul 18th, 2007, 1:34am I tried to simulate the phase noise of the VCO using the code in the paper "predicting the phase noise and jitter of PLL-Based Frequency Synthesizers". But i had a problem. The AMS simulator doesn't know, where is the file "phase.vams". I cannot find it also. Can you tell me, where can i get or find it? Thanks. |
Title: Re: "phase.vams", what is it? Post by ACWWong on Jul 18th, 2007, 2:48am did you read p12 ? you need to define the discipline phase yourself. if you use the other listings then you'll have to do the definition is a file called phase.vams |
