https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> no-ideal amp compling errors https://designers-guide.org/forum/YaBB.pl?num=1184913048 Message started by westwind on Jul 19th, 2007, 11:30pm |
Title: no-ideal amp compling errors Post by westwind on Jul 19th, 2007, 11:30pm I'm using the non-ideal opamp model from AHDL library in Cadence. The code is the same as one posted by hchanda: http://www.designers-guide.org/Forum/YaBB.pl?num=1165362179/5#5. when I compling this code, It gives me some error like " ERR732 [73:7]: Input port 'vref' can only be probed." I do not understand this, could anyone help me, thank you very much! |
Title: Re: no-ideal amp compling errors Post by Frank Wiedmann on Jul 20th, 2007, 12:09am A current is assigned to the vref port although it is only declared as an input port. Declaring it as an inout port will probably fix the problem. The compiler seems to have improved its checking, breaking old non-compliant code in the process. |
Title: Re: no-ideal amp compling errors Post by westwind on Jul 20th, 2007, 1:03am It has been ok, thanks a lot! |
