https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> comparator and pads in a sigma delta modulator https://designers-guide.org/forum/YaBB.pl?num=1184966134 Message started by filipe on Jul 20th, 2007, 2:15pm |
Title: comparator and pads in a sigma delta modulator Post by filipe on Jul 20th, 2007, 2:15pm To supply a Sigma Delta Modulator, I have two separated sources: an analog and a digital voltage supply. where should I supply the compartor??? With the VDD from digital or analog Supply??? Why?? Have you some references for this??? And the VDD of the PADs, where should I connect it??? VDDa or VDDd??? Why??? Thanks |
Title: Re: comparator and pads in a sigma delta modulator Post by Berti on Jul 23rd, 2007, 10:17pm You need the seperate your circuit blocks into agressors and victims. Since the comparator decision might be influence by spikes on the supply I usually connect the comparator to the analog supply (and provide local decoupling to avoid switching noise propagate through the circuit). The pad-ring is usually splited in an analog and a digital section (or even more sections for larger chips). However, if you don't want to split the pad-ring you can still supply the pad-ring with a seperate supply and provide analog and digital supply directly to the core. Hope this helps, regards. |
Title: Re: comparator and pads in a sigma delta modulator Post by filipe on Jul 26th, 2007, 11:59am Yes, it has been very helpful. In the case of the local decoupling to the comparator. Should I put a capacitor in parallel with the comparator source??? Which order??? Thanks |
Title: Re: comparator and pads in a sigma delta modulator Post by Berti on Jul 26th, 2007, 10:17pm For good decoupling you should put a resistor between the sensitive supply and your comparator supply (the resistors decouples the two circuits). However, often the speed of the comparator is critical and one cannot tolerate any voltage drop over a resistor. Therefore I recommenend to add only capacitance between vdd and gnd. Make sure that the capacitance is close to the source (in order to keep the switching noise localy). The capacitance value will depend on your comparator. Regards |
