https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> How to export the spectre simulated data to matlab https://designers-guide.org/forum/YaBB.pl?num=1185106684 Message started by caosl_zju on Jul 22nd, 2007, 5:18am |
Title: How to export the spectre simulated data to matlab Post by caosl_zju on Jul 22nd, 2007, 5:18am hi,all i want to export the simulated data from spectre to matlab for further process, but how to do this? I have tried the BYU website's method, (http://www.et.byu.edu/groups/ece451web/cadence-help/cadTOmat.html) But after simulation, it told me that the fprintf imcompatible with data...! any other good skills exist? or how to resolve the problem of fprintf imcompatiblity and improve the BYU's method? thanks in advance! |
Title: Re: How to export the spectre simulated data to ma Post by dmsaw on Nov 4th, 2007, 7:49am Using wavescan, you can save your data in a csv format that can then be imported into Matlab using csvread function. |
Title: Re: How to export the spectre simulated data to ma Post by Berti on Nov 5th, 2007, 12:21am Hi, ...or use the ocean-script command: ocnPrint. Regards |
Title: Re: How to export the spectre simulated data to ma Post by Paul on Nov 30th, 2007, 3:22pm Hi, If you have a recent version of Cadence, you may also use the Spectre toolbox in Matlab. See Andrew's post on this here: http://news.elektroda.net/cadence-matlab-data-transfer-t107674.html "The Spectre Toolbox is shipped in MMSIM61, and is in: <mmsimDir>/tools/spectre/matlab It's covered in <mmsimDir>/doc/spectreRFTheory/spectreRFTheory.pdf - chapter 1. Essentially, it gives you the matlab function cds_srr for reading psf/sst2 simulation results databases. " Paul |
