https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> question about the AAF in delta-sigma ADC design https://designers-guide.org/forum/YaBB.pl?num=1185437593 Message started by min on Jul 26th, 2007, 1:13am |
Title: question about the AAF in delta-sigma ADC design Post by min on Jul 26th, 2007, 1:13am Hi all : As general says : In designing a single-bit high-order delta sigma modulator , mainly use AAF before the loop filter,to prevent the saturation of modulator. My question is " If I design only a TWO order single bit delta-sigma modulator , shall I need to design the AAF?" thanks |
Title: Re: question about the AAF in delta-sigma ADC desi Post by hanm on Jul 26th, 2007, 1:55am Yes, of cource you need! The AAF is used to remove outside band interference. Which makes the input to the modulator a band limited signal. As you know sampling means frequency spectrum perodic occur at the integer times of sampling frequency. Alias occur if there isn't a AAF. hanm |
Title: Re: question about the AAF in delta-sigma ADC desi Post by min on Jul 26th, 2007, 2:36am Hi Hanm : Thanks for your reply. and i have another question " If in designing a high order loop delta-sigma modulator how the AAF can prevent the loop situation? As the AAF only filter the out of baseband signal ,it do nothing on signal band" Thanks |
Title: Re: question about the AAF in delta-sigma ADC desi Post by vivkr on Aug 7th, 2007, 12:50am Hi min, You should remember that the modulator will react to signals both inband and out-of-band. Since you are interested in inband signals, it makes sense to prefilter the input to minimize energy outside your band of interest. The NTF poles lie outside the signal band of interest and if the input to the modulator contains significant power at frequencies close to the NTF poles, this can excite it and induce oscillations, which are worse if high-Q poles are used in the NTF. Hence, the need for prefiltering. For more details, please see Chapter 5 by Bob Adams in the book by Norsworthy, Schreier and Temes. Regards Vivek |
