https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Big Contact vs Multiple Contacts https://designers-guide.org/forum/YaBB.pl?num=1185866241 Message started by qiushidaren on Jul 31st, 2007, 12:17am |
Title: Big Contact vs Multiple Contacts Post by qiushidaren on Jul 31st, 2007, 12:17am Hi all, Why we don’t use big contact rather than multiple contacts in layout? What is the reason? Regards, Terry |
Title: Re: Big Contact vs Multiple Contacts Post by vivkr on Jul 31st, 2007, 2:29am Hi Terry, This has to do with reliability. If you use a very large contact, then the metal may penetrate all the way to the active region (diffusion). This would then result in a short. Hence, one uses multiple contacts instead. Usually, the dimensions of individual contacts and vias are fixed for a given technology. Razavi discusses this and other issues in the last chapter of his textbook on analog IC design. Regards Vivek |
Title: Re: Big Contact vs Multiple Contacts Post by kwkam on Jul 31st, 2007, 6:43am Use of multiple contact result lower contact resistance than a single big contact |
Title: Re: Big Contact vs Multiple Contacts Post by sheldon on Aug 1st, 2007, 4:36pm Terry, One other reason is manufacturability. If the layout has large vias and small vias mixed in a layout. Then to resolve the small via windows, the large vias are overexposed. This results poor control over the large via windows and makes DRC checks more complex. The enclosure and overlap rules for via windows become highly area dependent. In addition to photo effects, the etch control also tends to suffer. As a result, the manufacturing guys strongly prefer layouts with a single fixed via window size. Best Regards, Sheldon |
