https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> voltage dependent capacitor model https://designers-guide.org/forum/YaBB.pl?num=1185880369 Message started by vivkr on Jul 31st, 2007, 3:12am |
Title: voltage dependent capacitor model Post by vivkr on Jul 31st, 2007, 3:12am Hi, I am trying to write a VerilogA model for a voltage dependent cap where C = f(V(cp,cn)) where cp and cn are the controlling terminals, and C itself is connected between 2 other terminals p & n. I always run into errors with the compiler which refuses to allow multiplication of a signal-based quantity with a ddt operator, or use of a ddt operator on the product of 2 signals. Is there a good way of making such a model. Incidentally, I am aware that modelling a cap like this is perilous, but for my testbench, it would work. Thanks Vivek |
Title: Re: voltage dependent capacitor model Post by boe on Jul 31st, 2007, 4:32am Hi Vivek, There are a few restrictions on using the ddt operator, try using an intermediate signal.... BOE |
Title: Re: voltage dependent capacitor model Post by vivkr on Jul 31st, 2007, 4:42am Hi Boe, Could you please elaborate? I did try to use an intermediate signal by creating a node and then trying to split the task of the voltage-dep cap by creating a voltage dependent function on this node and trying to use this to realize the cap, but it didn't work either. Seems like any reference to another signal, no matter how implicit, is banned, when used alongside ddt. Regards Vivek |
Title: Re: voltage dependent capacitor model Post by boe on Jul 31st, 2007, 4:53am Hi Vivek, I usually use something like Code:
And the ananlog operators (ddt etc) are not allowed in (dynamic) conditional statements, loops etc. (at least in my simulator)... Hope this helps. If not, please give a piece of code... BOE |
Title: Re: voltage dependent capacitor model Post by vivkr on Jul 31st, 2007, 5:55am Hi boe, I tried the intermediate node trick, and it does work. Thanks a lot. Vivek |
Title: Re: voltage dependent capacitor model Post by Ken Kundert on Jul 31st, 2007, 9:58am The techniques you are using are inappropriate and will likely result in incorrect results and convergence problems. The first problem is in the way you formulate your capacitor. When you calculate C as a nonlinear function of voltage, and then try to convert C to current, you end up with the wrong capacitance and charge conservation problems. You should instead compute the charge analytically, and then differentiate it with ddt() to compute current. This eliminates the accuracy problem. It also eliminates the problem you have having with the simulator, that leads you to your second problem. The second problem is that you are using an internal node, which also results in two problems. First, an internal node is kind of expensive. Second, it has the wrong tolerances. You declare the internal node to be electrical, but it is not. As a result, you are using the wrong tolerances for that signal, which can result in convergence problems if they are too tight or accuracy problems if they are too loose. I recommend that you follow the guidance provided in "Modeling Varactors", http://www.designers-guide.org/Modeling/varactors.pdf. -Ken |
Title: Re: voltage dependent capacitor model Post by safwatonline on Feb 16th, 2008, 6:40am Hi Ken, i saw your reply to the topic and i have a question, does these problems happen when the cap voltage is controlled by the same voltage on it, (i.e. in the case mentioned by vivkr where he have separate ports for controlling the cap, he shouldn't see that problems) or it happens even in that case. regards, Safwat |
Title: Re: voltage dependent capacitor model Post by Ken Kundert on Feb 17th, 2008, 12:49am If the controlling terminals are distinct from the capacitors terminals you still need to be careful or you will get nonphysical results. Imagine you had i = C(x)*dv/dt and C(x) was such that for some value of x, say x1, C(x1)=1 and for another value of x, say x0, C(x0)=0. Now set x = x1 and connect the capacitor to a 1v DC source such that v=1 and dv/dt=0. The capacitor is now holding 1 Coulomb of charge. Now change x to x0. Now the charge on the capacitor must be 0 because C is 0, but because dv/dt=0 no current actually left the capacitor. Charge is not conserved. -Ken |
Title: Re: voltage dependent capacitor model Post by safwatonline on Feb 17th, 2008, 1:18am Ken Kundert wrote on Feb 17th, 2008, 12:49am:
Thanks for the help Ken, i agree with you however what if i put I=dq/dt and q=C(x)*V then i should get I=C*(dV/dt)+V*(dC/dt) so while the first term will not introduce current, the second term will produce current discharging the charge, is that correct? BTW lets say i implemented this model how to verify it, since i don't have access to charges |
Title: Re: voltage dependent capacitor model Post by Ken Kundert on Feb 17th, 2008, 2:03pm Yes, you are correct, so your approach is fine as long as the capacitor is linear. However, I am surprised by your comment that you don't have access to the charge. For a linear capacitor charge is simply equal to the capacitance times the voltage. -Ken |
Title: Re: voltage dependent capacitor model Post by safwatonline on Feb 18th, 2008, 9:05am Ken Kundert wrote on Feb 17th, 2008, 2:03pm:
Thanks ken for your help, i think i got it now, so let me say what i understood, if C is not function of V ( even if C is changing on its own) then q=CV and i can use I=dq/dt without causing error and if C is a function of V then q =! CV but q=∫0vCdV, so i need to calculate the q analytically to maintain the charge conservation and i cannot use here q=CV as this is a linear equation which doesn't satisfy the C(V) condition. thanks a lot Ken. regards, Safwat |
Title: Re: voltage dependent capacitor model Post by imd1 on Feb 18th, 2008, 9:33am safwatonline wrote on Feb 18th, 2008, 9:05am:
The integral q=∫0vCdV is a path integral, have you any method for evaluating it ? I'd like to build a macro-model of a non-linear capacitance where q=C(v)*v and I was wondering if applying a sine voltage and integrating the current over a cycle would do the trick (of extracting the q=C(v)*v curve). BTW, anyone knows how dielectric loss and dielectric relaxation could be modelled ? |
Title: Re: voltage dependent capacitor model Post by Ken Kundert on Feb 18th, 2008, 9:09pm Well the point is that capacitors are charge conserving, so the path taken is irrelevant. So you just integrate the capacitance to get charge. Concerning dielectric absorption, check out the paper in the Modeling section of this site. -Ken |
Title: Re: voltage dependent capacitor model Post by Mihir Mudholkar on Aug 12th, 2010, 12:06pm Thanks a lot Ken for your valuable advice. I was also facing the same dilemma, however in MAST (Saber). The link you attached for your explaination of modeling non-linear capacitances is excellent. |
