https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Cadence - Frequency Response https://designers-guide.org/forum/YaBB.pl?num=1186507257 Message started by Mikey on Aug 7th, 2007, 10:20am |
Title: Cadence - Frequency Response Post by Mikey on Aug 7th, 2007, 10:20am The intention is to simulate a frequency response of a mixed signal system. Doing the usual ac sweep is not possible. I have obtained a impulse response for my mixed signal block. This is a time domain representation. I can perform a dft using the cadence calculator. How do i get a magnitude and phase response plot from the latter? I hope cadence could support this query? Best Regards, Mikey |
Title: Re: Cadence - Frequency Response Post by aamar on Aug 9th, 2007, 1:02am Hallo, I can understand from your question that the case you have includes an analog signal and a digital clock signal, (something like switched capacitor circuits). Then the suggestion would be the PSS and PAC simulations. There is already a guide for this tool under the following link http://www.designers-guide.org/Analysis/sc-filters.pdf best regards, aamar |
