https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> bondwire inductance matching https://designers-guide.org/forum/YaBB.pl?num=1187873914 Message started by aaron_do on Aug 23rd, 2007, 4:58am |
Title: bondwire inductance matching Post by aaron_do on Aug 23rd, 2007, 4:58am Hi all, how well matched are bond wire inductances? For example, if i have a differential LNA and each half needs a separate bondwire inductance, how good is the matching? Also, how accurate is the absolute value of the bondwire? thanks, Aaron |
Title: Re: bondwire inductance matching Post by ACWWong on Aug 23rd, 2007, 8:57am bonder repeatability is excellent, landing points are typically +/-10um, and looping is very well controlled. matching other than this will depend on your bonding diagram and pin-out/leadframe. For well matched bondwires of course you must pay attention to these (critical high frequency differential pads on the middle of the die/package sides are best because they are short and less exposed to ESD events). Modelling can be complicated by adjacent (adjacent +1, +2 etc. as well depending on land pitch), so a good em simulation of bondwires and package is needed. |
