https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Corner reflector antenna design https://designers-guide.org/forum/YaBB.pl?num=1188375709 Message started by Tronix on Aug 29th, 2007, 1:21am |
Title: Corner reflector antenna design Post by Tronix on Aug 29th, 2007, 1:21am Hey everyone I desperately need to design a cheap but effective corner rflector antenna with the ff specs: • Gain at centre frequency, fc: 15 dBi • Centre frequency, fc: 600 MHz • Input impedance: 75 Ohms • Sidelobe level below main lobe(s): >40 dB. Anyone with anything that can help please help me up. Im desperate Tronix |
Title: Re: Corner reflector antenna design Post by didac on Aug 29th, 2007, 2:45am Hi, Take a look at: http://www.northcountryradio.com/Articles/crfl.htm http://www.qsl.net/ve3rgw/corner.html also I think the book "Antenna Theory: Analysis and Design" by Constantine A. Balanis will be useful, probably will also be useful the book "The ARRL Antenna Book" by the ARRL(not sure about this one, I read it time ago). Usually radio amateur webs contains useful information for the design of cheap antennas. Hope it helps, |
