https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> how to modeling a full differential opamp ? https://designers-guide.org/forum/YaBB.pl?num=1190215199 Message started by zhujun134 on Sep 19th, 2007, 8:19am |
Title: how to modeling a full differential opamp ? Post by zhujun134 on Sep 19th, 2007, 8:19am hi,all; i am designing a sigma-delta ADC,when i want to model a full differential opamp block,then i can find the parameter of opamp how to influence the performance of modulator,but i can not built a full differential opamp in veriloga,and the opamp can inculde these parameter of slew rate,gain,frequency-gain,rout and so on! i have modeled a opamp reference to opamp in ahdlLib in cadence,but i can not work at all. would you give me some advice?or give some example?thank you in advance! |
Title: Re: how to modeling a full differential opamp ? Post by alonso on Oct 30th, 2007, 7:59am Hi, When I had the same problem, I used a macromodel for the amplifier modeling. I hope it will help. Regards, Alonso |
Title: Re: how to modeling a full differential opamp ? Post by jbdavid on Nov 30th, 2007, 1:40pm There are a good number of legacy examples in the forum here.. Use the search function.. Thats why we should have a wiki.. eh? |
