https://designers-guide.org/forum/YaBB.pl Design >> High-Speed I/O Design >> How to create a skewable testbench source. https://designers-guide.org/forum/YaBB.pl?num=1190658693 Message started by svenn on Sep 24th, 2007, 11:31am |
Title: How to create a skewable testbench source. Post by svenn on Sep 24th, 2007, 11:31am Hi, how do you guys create a differential input pattern generator to check how a cml buffer chain reacts to skew in input signal? Hope to be able to have something usable for a parametric simulation of a buffer chain with a bit of level converting. |
Title: Re: How to create a skewable testbench source. Post by loose-electron on Sep 27th, 2007, 3:04pm is this in simulation testbenches or "on the bench with a soldering iron in hand" type of bench? |
