https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Array declaration for analog output https://designers-guide.org/forum/YaBB.pl?num=1192685339 Message started by shaikhsarfraz on Oct 17th, 2007, 10:28pm |
Title: Array declaration for analog output Post by shaikhsarfraz on Oct 17th, 2007, 10:28pm Hi All, Is it possible to declare an analog output array of a sensor block in verilog - ams? Here is what I am doing module XYZ (in,out); output [Array_size-1:0] out; Now how to declare this output out net i.e whether to use wreal or electrical or is there any other assignment. The port out is supposed to carry analog signals. Regards Sarfraz |
Title: Re: Array declaration for analog output Post by jbdavid on Nov 30th, 2007, 1:38pm If "out" is wreal you'll have to declare an array of real, and do an assignment from the real array to the wreal array, if "out" is electrical, you'll have to create a contribution statement for each wire in the bus. jbd |
