https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> TX SNR https://designers-guide.org/forum/YaBB.pl?num=1195558069 Message started by aaron_do on Nov 20th, 2007, 3:27am |
Title: TX SNR Post by aaron_do on Nov 20th, 2007, 3:27am Hi, does anybody know what sort of SNR we can expect from the transmitter output? I was thinking it would be in excess of 50 dB... thanks, Aaron |
Title: Re: TX SNR Post by pancho_hideboo on Nov 20th, 2007, 6:54am Hi. What is your definition of SNR in TX ? If you are thinking of non-modulated signal, SNR you should evaluate is C/N or C/N0. Here you have to consider bandwidth or offset frequency. For modulated signal, SNR you should see is ACPR. And you have to see noise floor for out of band region. This out of band noise floor level is important for CDMA system. I make level diagram for TX which plot cascaded ACPR anf noise floor level, here I need P1dB(IP3) and NF of each stages. You are thinking of this out of band noise floor ? Higher order harmonics, images of DAC, Local Leakage, etc. are treated as spurious. |
Title: Re: TX SNR Post by aaron_do on Nov 21st, 2007, 4:32am Hi, thanks for the reply. I was actually talking about the signal power to the channel thermal noise ratio. As far as i know it is not normally considered in design, and when I asked a colleague he said it would be only 9 dB for GSM and 18 dB for WCDMA. I assumed he was talking about the signal to thermal noise power, but i guess he meant ACPR. I think I need to do a little reading :) thanks, Aaron |
