https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> recommendations for 50 ohm buffer design https://designers-guide.org/forum/YaBB.pl?num=1196149609 Message started by aaron_do on Nov 26th, 2007, 11:46pm |
Title: recommendations for 50 ohm buffer design Post by aaron_do on Nov 26th, 2007, 11:46pm Hi all, i'm just looking for recommendations on 50 ohm output buffer design using 0.18 um CMOS. Its for on-wafer probing and the output signals are differential. Also the equipment is all 50 ohm. It is for a frequency range of 0.1 MHz to around 50 MHz. thanks, Aaron |
Title: Re: recommendations for 50 ohm buffer design Post by edward.yin on Dec 1st, 2007, 12:37am I need it too, I find it so difficult to design if your power consumption budget is limited. Always, I will use the emitter follower, but it needs a lot of current to drive 50 Ohm load. |
Title: Re: recommendations for 50 ohm buffer design Post by pancho_hideboo on Dec 1st, 2007, 2:04am What amplitude do you expect in 50ohm load ? Buffer amplifier have to have current sink and source abilities which satisfy current>=amplitude/50ohm as well as voltage headroom. If amplitude is large, we can't reduce MOS size and bias current. But if amplitude is relative small and frequency is around 50MHz, the design specification of your buffer is to achieve low output impedance. In this case, you can realize low impedance by source follower having local feedback without increasing bias current. |
Title: Re: recommendations for 50 ohm buffer design Post by loose-electron on Dec 6th, 2007, 5:17pm consider an OTA (current dumped out) type of output into an external resistive load. With an internal feedback amplifier to adjust the output current, these generally give reasonable results. Its a class A amplifier and not power efficient, but if you are driving an external 50 ohm load there really is not much that can be done for power effiencency. |
Title: Re: recommendations for 50 ohm buffer design Post by Berti on Dec 6th, 2007, 11:35pm Hi loose-electron, the proposed circuit sounds interesting. But what's about linearity? Do you think 14-15b linearity can be achieved with such a structure. However, does anybody have experience with buffer design for applications where very high lineariy is required (14-15b)? Because this can't be achieved with a simple open-loop circuit (e.g. source follower). Regards |
Title: Re: recommendations for 50 ohm buffer design Post by aaron_do on Dec 7th, 2007, 12:24am Hi, thanks for all the replies. The output swing is not large, but i'm worried about linearity and noise and also gain accuracy. Anyway since it is a low frequency design I decided to design a simple instrumentation amplifier with a resistive divider at the output for the 50 ohm load. Noise performance is good enough for my purposes i guess. cheers, Aaron |
Title: Re: recommendations for 50 ohm buffer design Post by loose-electron on Dec 11th, 2007, 12:58pm Berti wrote on Dec 6th, 2007, 11:35pm:
Agreed - a source follower is not going to be able to get it done unless the signal is an extremely small part of the bias current - thus - really inefficient. The linearity of the OTA structure has 2 parts to be considered - -- linearity over what bandwidth? -- how much gain is in the feedback loop? lots of open loop gain feedback will get you to a good linearity, but only for low frequencies. As the OTA BW starts to play in, the linearity gets worse at high frequencies. Now, what constitutes "low" and "high" frequency remains open for discussion. Can you get good enough linearity? Need to put some numbers on it in terms of required linearity over what BW. I have used this tyoe of teshnique up to 100MHz in 0.25 CMOS, with reasonable results. |
