https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Threshold Voltage calculation in Eldo https://designers-guide.org/forum/YaBB.pl?num=1196227343 Message started by Analog Designer on Nov 27th, 2007, 9:22pm |
Title: Threshold Voltage calculation in Eldo Post by Analog Designer on Nov 27th, 2007, 9:22pm Hi, I am trying to extract Vt of MOSFET using eldo. I could not get correct value of Vt using the functions maxgmvt, lv9. Does any one has suggestions on how to extract max-gm based Vt using Eldo? Thanks AD |
